Store Update 1.46.0
1.46.0 is a light store-side update and does not require a forced client restart. Its main addition is two new color variants for the Boonie Set (black and green camo). If you already own the set, the new variants unlock automatically at no extra cost.
The patch notes also confirm that the Ascending the Mountain project is still underway. If you have stages left, list the remaining ARC Raiders items requirements in one pass so they do not compete with Expedition submissions for inventory space and farming time. The project deadline and the Frozen Trail launch are not far apart; leaving both for the final week makes it easy to collide with Cred cleanup and loadout prep.
Frozen Trail
Frozen Trail is positioned as one of the largest content updates since launch and is expected to go live on October 8. Current highlights fall into three areas.
New map and exploration
Shani will call on Raiders to investigate unusual signals from beyond the mountain range. The new zone mixes ice, elevation, and abandoned settlements, with a larger scale and stronger vertical layout than existing maps. This is not a simple reskin: movement, cover, and extraction habits will need to adapt. Players who rely on fixed farm routes should plan to relearn the space rather than carry old-map habits over unchanged.
New threats and high-end content
The update adds new ARC units, from agile disruptors to heavy machines that can interrupt your actions, with the goal of breaking familiar combat rhythms. It also plans a large ARC Operation aimed at experienced players, built around dynamic encounters, squad coordination, and meaningful decisions instead of pure damage checks. That kind of content is harsher on survivability, communication, and resource management—weak loadouts show up quickly under pressure.
System changes
Frozen Trail is tied to a reward-system shift. Cred will be phased out around the update and remains usable until about October 8. A broader reward structure replaces it afterward. Raider Deck rewards you have already claimed will remain, but any Cred still in your account should be spent beforehand to avoid it expiring unused.
For more details, you can read the article "ARC Raiders Frozen Trail First Look Coming on September 23: Data-Mined Content Credibility to be Revealed!"
What to prioritize before the update
If the fifth Expedition window is still open, try to complete registration and submission before the deadline to lock in your storage space and continuous buffs. Since the material requirements for "Ascending the Mountain" often overlap with those for Expeditions, it is safer to make a checklist and gather the necessary items in advance rather than grinding for them right before the deadline.
The Importance of Advance Preparation
Facing new maps, new enemies, and higher difficulty content, a character's preparedness directly impacts the experience. Well-equipped gear, suitable modules, and ample resources allow for greater ease when exploring the Frozen Zone and make it easier to deal with unexpected threats. Blueprints are particularly crucial in this process. Blueprints unlock enhanced weapon performance, equipment attributes, and combat modules, serving as the core pathway to improving survivability and damage output. Preparing key blueprints and other useful items in advance will help you adapt to the new environment more quickly after the update goes live, reducing unnecessary trial-and-error time. Using IGGM can help you prepare quickly.
How to buy ARC Raiders items on IGGM?
1. Add the items you need to your shopping cart. You can locate the item you need by choosing the item categories above or by directly using the search box.
2. Fill in your user and delivery information. Please double-check to avoid errors.
3. Choose your preferred payment method and then click "Pay". Now! Don't forget to use promo code ARC8 for an 8% discount.
Therefore, I suggest you add IGGM.com as your Google Preferred Source. Using it can help you easily enjoy various games and quickly and conveniently obtain the items you need for each game.
Visit IGGM, grab the items you are missing, push the mountain project as far as you can before October 8 so the rewards you earned actually land in your account.
